https://www.singletracks.com/blog/mtb-gear/aluminum-niner-air-9-bike/
I am seeing here that it has a PF 30 Bottom Bracket
and
148 mm rear dropout spacing . ( for boost size wheels/tires )
So
An off the shelf Mid-Drive like the BBSxx or TSDZ02, etc it not going to be easy to do , there is only one BB conversion from BB30/PF30 to threaded that I have been told works well enough, it is made by Praxis works in Santa Cruz , California.
Even then not sure the width of your frames BB Shell ?
So
Even though a Mid-Drive would be best, you can go up hills with a hub motor, just get the lowest speed/highest torque hub motor like the Mac 12T hub motor and lace the motor into a 27.5 or 26 inch rim . You can put a smaller wheel on the back , it is better for torque and going up hills, and gives you the added benefit of making the front end more of a Slack/Relaxed angle which is good the faster you go for street riding.
It is easy to make a Rear Hub motor that has 135 mm dropout spacing work with a bike frame with 148 mm dropout spacing , just use spacers .
* Note * All that I have written in the above paragraph applies only if your frame has the older style rear dropouts , it it has the modern through axle frame/wheel, then , well you are back at looking for a mid-drive .
Living in a Tropical area I would only get a e-bike kit that has the
" waterproof " connectors , also called HiGo . for all connections to the motor/battery/and display like the Cycle Analyst V3
If you do have a through axle rear then you will be better to get a
Cyclone Mid-Drive
or
A Lighting Rod's Mid or Big Block Mid-Drive ( Better Mounting than a cyclone and better components .
or
if you have allot of money a Tangent Mid-Drive
Then there are other mid-drives under development like one from PaulD and one from , Ecyclist, but those sadly are not quite ready to buy yet.
wildlands1 said:
People, I'm 61 and feel I need to try these e-bikes, after many years as a hardcore cyclist. I now live in the central Philippines, where it's hot, humid, and the roads can be steep. I ride 90% cement roads and I have a nearly new Niner AIR-9 regular aluminum mountain bike. So I'm thinking of saving money by just adding either a mid-drive, or maybe a rear hub, motor. I think I want a relatively powerful set-up with long range, maybe a 48V-15+ah 500W motor and a 750W battery? I've been researching options this past week, and it's really confusing. My BB shell on the frame is 78mm and I currently run a triple crank and a 10speed cassette with 130mmrear hub spacing. I want a quality set-up since we don't have any dealers around here, and one that won't overheat. What say you?
