I just ordered 160 high-current 21700 cells (Samsung 40T) to build a battery for my electric-converted Vespa.
It already has one 20s8p battery built with the same cells, I'm building a second one for additional range, and to reduce heating of the battery during sustained high-power usage (70-100A @ 72V).
This is my first battery pack build. I've already ordered a Sunkko 709A spot welder. I've not yet gotten cell holders and nickel strip. I'd like to do a honey-comb configuration to keep the size down. As I'm spreading the load across two of these battery packs, cooling shouldn't be a problem. The existing pack is honeycomb configuration.
I'm a bit apprehensive about buying the nickel strip from "any old vendor" on Amazon for fear of getting nickel plated steel advertised as pure nickel.
I'd like to do 10mm X .2mm for the best current capacity. I'd like to be able to run the scooter off one pack at a time if needed, thought will almost aways run both. When running one, continuous current climbing hills can be as high as 120-140A for the pack, or, 12-14A per cell. More commonly the draw is more like 50-70A.
When running both packs, even climbing hills, I'll be at about 7A per cell max, well within the ampacity of 10x.2mm nickel.
So, what is a reliable vendor to get 10x.2mm nickel strip from?
Is it available in wider widths, 12mm, or 15mm? That'd be better yet!
Also has anyone here welded .2mm with the 709A? Does it do well. From what I'm reading, I need to use the fixed-mount electrodes to weld .2mm strip, that the hand-held "pen" is only good for .15mm.
