osa57
🔌 New-ish
- Joined
- Feb 14, 2013
- Messages
- 24
I have already used 9Continent RH212 hub motors with Phaserunner and everything was always fine, regen did work immediately well.
Now I have a Baserunner (no Phaserunner are available...) and this is my setup:
- 48V battery
- RH212 9C hub motor
- L10 Baserunner
From the Phaserunner suite this is what I see:
1. The "ebrake" flag and the "Regen" flag do not light up when I pull the brake
The "Throttle voltage" goes to 0,40V when I pull the brake and down to 0 when I also push the throttle
2. Brake voltage (1) stays always = 2,84V
3. Wheel speed sensor Voltage (Brake Voltage 2) fluctuates from 4,5V to 0,03V
I tried to add the following parameter: Addr 249 Regen Brake Source and to modify it
- from Brake 1 to Brake 2 >> nothing changes
I also tried to add the following parameters:
Addr 212 Analogue Braking Enable : >>> no changes
Addr 212 Engine Braking Enable : >>> no changes
Do you have any guess why REGEN is never triggered?
thanks
Daniele
- 48V battery
- L10 Baserunner
thanks
Daniele
