NaCly
Hi ES, it's my first post here and I'm already stumped by my own overzealous, careless planning.
I'm trying to convert a Marlin 7 Gen 3 with an RH212 hub motor, and discovered that the bike has an SRAM Eagle SX groupset. The RH212 hub motor has a standard Shimano HG cassette freehub like most others, and I was wondering if I could do one of the following:
1. Use an HG-compatible cassette on the hub motor; the tricky thing is that the groupset I have is 12-speed, and I don't know if there are any 12-speed, SRAM Eagle compatible cassettes that also mount on an HG body. Does anyone know if there is one?
2. Swap the freehub; on Grin Tech's RH212 disassembly video (5:20), the freehub assembly seems to be one-piece, but there is a bearing on the inside. This makes me wonder if I could swap the freehub to the SRAM Eagle one, but I don't know if it's possible to disassemble the freehub from the 6-bolt part that mounts the splined part onto the hub motor. I really do not want to do this and might even consider swapping the entire groupset before I break the seal on my already Statorade-injected hub motor. If the freehub assembly cannot be further disassembled, then I might even seek for somebody to CAD model and manufacture one for me. It all comes down to cost.
Thank you for reading,
NaCly
NaCly
