I've been researching LiPo, been reading many posts here, but still have a few questions. I've searched for answers but could not find them so I apologize if this has been asked before.
I understand what the C number refers to but don't understand all the implications. With a 48V 500W motor, if I push more amps (higher C) then the motor will deliver more power (Volts x Amps = Watts), kind of like opening up the throttle and supply more fuel to your gas engine, right? But is the motor rated to only handle a certain amount of amps and above that it could burn out? Basically I'm trying to figure out what C rating from my battery pack would be ideal for my motor. Are there other advantages to have a higher C rating other than giving your motor more power when you need it? How does the motor controller fit into this equation?
Also, the higher amp discharge will drain the amp hours quicker but does it also reduce the voltage of the pack, drop the voltage down? I read I need to be concerned about the voltage dipping below 3.2 or so.
I was reading that it is bad to fully charge your battery pack to 4.2V, especially if you leave it on the charger. Do they not make a charger that you can set to charge to 3.9V (for example), and then it shuts off the charging? It would be a real problem for me if I have to monitor the charging that closely, I would like to just set the pack on the charger outside and leave it.
Lastly, I was looking on hobbyking at the different packs, is there an advantage to buying several smaller packs and series them together or.....? I see people refer to 5s or 6s packs like there is some advantage to a certain configuration. Is there much difference to getting 3 4s 14.8v packs as apposed to 2 6s 22.2v packs?
Thanks.
Thanks.
