Merlin said:OK...
But please don't tell that the stock battery....
Iam afraid she will wake up and start limiting the power :lol:![]()
Merlin said:OK...
success with it :thumb:Merlin said:
She just likes me and don't restrict my bms :lol: :lol: :lol:
... But before you freak out. I have a range extender battery added ^^
Peterfr12 said:Hi all,
I purchased a MXUS 3kW hub motor and a Nucular 12F controller. It will be used for a recumbent bike and a 20s14p battery.
Sorry for the dumb questions!
From the hub motor there are several cables of different colors. There are yellow, green and blue thick phase wires which must be connected to the blue phase cables of the nucular controller. With my former em3ev setup I had to obviously match the color. Here it does not matter. Am I right?
Then the hub has 2 set of temperature and hall wires: white (temp), green, blue, red, black and yellow. Obviously, I just use one set. From the Nucular controller there are also 6 wires of different colors: yellow, green, orange, white, black and red. I guess I have to match the red wire of Nucular with the red wire of the hub, black with the black, white with the white, yellow with yellow, green with green and the blue wire of the hub with the orange wire of the controller.
Am I right?
Thanks for your answers.
Best regards,
Peterfr
any idea what the stock controller wh/km was?Merlin said:Merlin said:shortening the throttle V we did also on adappto. 3v was perfect. i will try the PID settings but i think the cuttet voltage did the trick....i hope iam wrong =)
unfortunately i wasnt wrong
PID didnt do anything in acceleration from zero. (without the voltage cut)
But Surron peaks 8.5Kw, 80kph@50a flux with 58T.
So its pretty good. Of course Torque Throttle and smooth as butter
efficiency as expected to the stock surron controller way better. 28wh/km @ straight 50kph(gps)
Running 4Kw (70kph) for half an hour: controller 38°c - Motor 68°c
best upgrade ever for your surron =)
Merlin said:but as now a bunch (5 ppl) of my buddies riding the nucular we found that the consumption is between 10-15% off the "real capacity"
ride it down til the bms trips...and shows 45V, the display can run on the battery the lights not so the bms cuts the power. The cells wil be like 3/3.1V if you measure straight on the cells.Merlin said:2,81v/cell is pretty deep. stock battery cuts off 3.0v ?!
looks like you are just guessing. after this discharge you need to charge it with something that reads wh
i bet my left ball that using a satiator your charge will end up ~1800wh
180-200wh difference is the ~10% we are talking about.... 6-8km difference. a looooong walk of shame![]()
Joachim said:ride it down til the bms trips...and shows 45V, the display can run on the battery the lights not so the bms cuts the power. The cells wil be like 3/3.1V if you measure straight on the cells.
i measured. nucular display show a bit more voltage as it is. (4 installed allready)
67.2v straight at battery is 67.4@display. If my display would show 45v it would be below 2.81v
i have also a balance lead at my lmx battery and that shows also less voltage (quality multimeter)
Recharge no problems. (stock bms?) our l1e have not the first series problems with "charger wont start" if its below xy voltage
you can probably reload it somewhere between 1700 and 1800Wh,
thats what i think if you use a "good/precise" charger or ca with calibrated shunt just to check whats going in.....
but that does not mean that this can also be used. a Panasonic PF that gets discharged with more than 1C / 3Amp often gives only 2650 to 2700Mah
right. but i think/hope your end of ride while bms tripped doesnt mean you cutted it off on full throttle? i thought you have run the last mile on very low power until it cuts off (45v) If so, discharge is something around 1A/cell and then we get more wh out of a (new) cell like yours.
I tested for example sony vtc6 with 1a discharge and got 3100Ah out of it discharging to 2.99v
(4.18V down to 3V) and then you have not included the losses from battery to controller and motor.
*shrug shoulders* we are poking in the dark
very theoretical. All i want/need is the wh usage/battery bar to real world using. so if my battery charges back more then nuc used. i dont care.
my 2.75kwh i have set to 2.5kwh and i can ride very precise to 0%/0wh left and the bike rolls on wot only up to 10kph.
even if wh shoes wrong usage, even power shows too much or 10% less. i dont care. Bike runs best as possible. statistics suck and i dont get it why there are no fixes out yet for simple stuff. before fixing, vasiliys todo list grows with (for now) unnessesary new features in my opinion. 2wd drive, smaller controller cases and stuff like that. controller is TINY enough, 2wd users are 0,1% of all users.
if the cells fall below 3.5V the internal resistance also rises quite well and you also lose a lot of energy in the form of heat, which will not work very positively with 176 cells so close together in a sleeve. A loose cell testing is fun but in a battery with 174 cells everything becomes really different.
lukashanak said:Yes, FOC Ki is integral therm of FOC mode PID regulation.
Things i've done for fast throttle response:
Running torque mode
In control modes acceleration limit set to 0
Shortened my throttle so max volt on WOT is only 2.8 not 4.4v and made auto throttle calibration for this voltage.
And adjusted PID. FOC Ki to 120.
But now is to much for me. Its more aggresive than my previous Sabvoton 72150 on same phase amps. On higher gears OK, but on low gears its dangerous...
jameswalker said:What are the best control modes plus throttle config for wheelie control, would anyone know?
I am almost at the point where I can test this thing out for real! Hopefully tomorrow.
