Lessss
http://www.fireflyenergy.com/images/stories/pdfs/G31%20Specification%20Sheet%20012308.pdf
Anyone try these out yet?
The big difference is that they don't wear out as fast.PJD said:Nothing too impressive on the sheet as far as energy density goes. Same as the SLA's I currently own.
gogo said:Show us the numbers you are using.
safe said:A Bizzare Design Idea?
Lets just say I'm not particularly flattered.Toorbough ULL-Zeveigh said:The internal resistance is so low that it might be possible to use just a single tied to a hi-wattage DC converter.
That's why I was thinking of the RC motor since it can take the 12 volts and still do something useful with it. Ideally the Oasis battery needs to come in sizes that ebikes can use like 12 ah or 18 ah. 100 ah is just too hard to manage for anyone that doesn't have a custom built frame.MitchJi said:70 lbs for a 12 volt makes them pretty hard to justify for an ebike. Might be good in a Motorcycle.
The D-sized cells using the battery pack are intended for use in electric bicycles and motor scooters, but were installed in the Prius to demonstrate the viability of NiZn chemistry in hybrid applications.
