teklektik said:
GCinDC said:
... as the seal on the disk side blew and a bulb of oil appeared.
What does this mean exactly? Did the lip/retaining spring deform and actually blow out or did it just leak?
The oil seal lips are very easy to damage...
sorry, that was a hasty description... i was riding along and heard an odd thump. i stopped and noticed a swell of oil on the sidecover edge, which i'd sealed w/ marine caulk - and it was the disc side, which i'd sealed the night before, so it had the night to set. but as you may have noticed, i didn't put much, and went to the outer edge of the screw holes, wanting to keep any excess away from the magnet ring... in future, i'll use more sealant.
anyway, i wiped away the oil, and saw no gap or anything. it could have been a drip build up from something else, but it wouldn't have been directly over the sidecover seal, esp if it had dripped out the axle and and down the side of the motor, which some oil had done.
what are the oil seal lips? sounds like those black rubber things that seat into the sidecover around the axle from the outside? i thought those contained the coil that everyone says cuts the wire, and i considered removing it, but i saw no evidence of the coil, and chose instead to use a wire tie to keep the wire away from that rubber.
i thought i read before that the bearing was going to have to be the barrier... now that i think about it, i should have probably caulked around the bearing. both popped off the side cover and had to be replaced. one slid halfway into place and then had to be smashed the rest of the way. probably not best practice, but i've got another hs3540 with a bearing only halfseated, or so i think, with a bowed sidecover... and i didn't want to install it that way, not with this mofo wheel.
pwbset said:
thank you SO much for that "how to" video.
thanks. i had a heck of a red mark on my forehead from wearing the gopro (on an improvised head mount) :lol: i cut the hours and hours of searching for tools to show just the important parts, but there's a whole lot more to the job. so a much larger how to vid would have to be done, including choosing and installing your temp sensor, as well as upgrading your phase wires, which is a job unto itself on a 9C.. (which i didn't do this time, but will probably do tomorrow night, now that i'm depressed and bored that this project is over. :lol: )
hjns said:
Does the Clyte also have a separate hall pcb? I will cover my halls / hall pcb with silicon muck.
no separate hall pcb. mine has three (left) plus one thermistor, which i replace w/ lm35. before:
after (still wet):
i was most concerned with creating a web around the hall legs and wires, but might even suggest removing the silicon which is easy and embedding halls in jbweld.
but this is wild west territory, so good luck to you. whether it lives or dies, take lots of pics.
