DeathBlade
- Joined
- Oct 18, 2008
- Messages
- 111
I'm thinking of a new lipo setup for my GM motor I'm guessing a total 12s2p(or4P) from two 6s packs(still deciding on which are the best/cheapest on hobbyking). Now I've got some 0.083" aluminum diamond plate I'm going to make my battery box out of for my diamondback response and the way I'm designing the box it will be a pain to open it up every day or so. So I'm thinking an onboard charger.
Just how? I know I could get a set of chargers and put them in with the lipo but then most chargers aren't meant to go on the RC let along a ebike.
So after some googling I saw this http://www.experiencerc.com/store/product_info.php?products_id=8969
and this http://www.robotmarketplace.com/products/0-UB26.html
The first has a nice screen and the second just seems rugged from a KISS stand point. So I'm thinking I could use two of them and parallel the packs and throw in a interrupter switch between them to take them from 12s to 6s. Now for a charger I've got some inverter power supplies (sure one is inverter arc welder but a power supply is a power supply :lol: ) that do 48volts or 40 open circuit in the case of the welder. I'm thinking a relay to disconnect the power supply after it reaches a full charge I can probably set up some type of charger this for this I think onsemi or national have some decent programmable charger ic's that are simple enough I know I have some in 12volt I just need to remember were I got them.
The only problem is how do I get it all together. Anybody done this on their builds? I really want this to be KISS high speed charging fast charging is not needed If I'm anywhere I can charge I'm staying there a while ie: work, home, hackpittsburgh, etc. I'm going to feel really stupid if there is a premade onboard charger our there.
Any thoughts?
Any thoughts?
