cell_man
Sag to 3V isn't so bad. I wouldn't worry about it. In EV applications the TS cells often get pulled a lot lower than that.
morph999 said:Just checked all the cells. They are all 3.36v and the bad one is 3.35v while at rest. And the bad cell is 3.05v under load (discharge). The whole pack sags to about 35.5v under full 40 amp load. Under about a 20 amp load, it only sags to about 38v.
So what should I do? All the cells are reading about the same under rest. Maybe there is nothing wrong after all.
I wouldn't really be overly concerned about it like Cell-man said its fairly normal. But I would keep an eye on it, and using less amps would help the longevity.morph999 said:Under full load, it's sagging to about 35.5v . That's 12 cells. That's bad. Right?
It would have to be a trade, I just bought 55v x 15ah of Lipo and my fiance would kill me if I were to buy anything else :lol:It's the 5303. You guys were right. It's just too big and too much of a power hog.
I'm going to sell the 5303 hub motor. I think Nomad85 might want it so I'll offer to him first. It's only got 150 miles on it.
I really wouldn't recommend using that forsen motor, It would be better to go easy on the throttle with the 5303 IMO.What do you guys think I should do? I don't mind going 20 mph. I think I need about 15 AH of battery no matter what I do because I don't like pedaling. I hurt my leg recently and the 5303 has been a real help because I can go places on it without having to pedal. I can probably do that on the forsen too, though.
morph999 said:I'm reading on other forums that this is normal, for the cell to bleed down to 3.36v after charging. Why my other cells aren't doing it is a mystery. Don't knock Jack Rickard, he knows his stuff. I think lithium is still a bit of a mystery because one group is saying that surface charge bleeding down to 3.35v is normal and another group is saying that it's not normal. Maybe if I continue running my batteries, we can find out if it's normal or not. If these last more than 500 cycles, then we'll know that it's pretty normal.
I don't ride my bike everyday so if these can just last 4 years, that would be awesome.
morph999 said:If the cell was damaged, wouldn't it be falling well below the others upon discharge? Seems to be falling right in line with the others right now. I'll put in a 10AH run tomorrow or whenever it's sunny again and we'll see what happens. I was expecting to see like 2.6v or 2.5v upon discharge but it didn't do that.
morph999 said:Just took the bike out. The bad cell goes to about 3.05v under full 40 amp load. That's with only about 1 or 2AH used...with 10 AH used...it's probably much worse.
quote]
When I first did my cells I did a stall test with my CA. These are my results.
Starting at 74v = Cell voltage 3.7v. Fresh off charger.
55.98A load. = Almost 3C for these cells gave me 57.1v. This gives me a cell voltage of 2.85v under load.
Again i think you are making a big deal out of nothing. These cells have a high sag to them but they are made for 2C constant load.
If you read the specs if the temps are really cold these cells are allowed to sag down to 1.5v at -35C and 2.5v at 25C.
The manual also states that running theses cells down to 2.0 to 2.5v is ok and shouldnt damage them.
http://www.thunder-sky.com/pdf/2007030222.pdf
AussieJester said:Morph, is you controller programmable? if so perhaps simply turn down
the settings so you can't pull more from the batteries than they can put out?
Don't cycle analysts have current limiting on them? Would be cheap'er' option
if you have non programmable controller, cheaper than than buying new pakcs if these ones get damaged from pulling to high amps.
KiM
morph999 said:Why would voltage sag kill your cells? There are two ways of thinking about lifepo4: one says that voltage sag can kill your cells no matter how many AH you've used from it and the other says voltage sag doesn't matter and it's how many AH you've used. Don't the experiments show that voltage sag doesn't matter? All the charts that I've seen show that a 3C discharge will kill a thundersky cell much quicker than 2C discharge but you still have to actually use almost 70 - 80 % with a 3C load to actually kill it. It's not going to die after only a few minutes on a 3C load.
Andy, your own charts show that voltage sag don't kill cells, it's the amount of AH used. Look at the cells rebounding after voltage sag. You are essentially saying that voltage sag kills cells so if that were true, we would see the cells that fall below 2.5v just basically be destroyed but that's not what it shows. It shows the cells rebounding.
liveforphysics said:It's like talking to a wall Andy. He knows everything all ready. Jack and Morph are the battery experts on this board, and anybody trying to talk some sense on the subject is just trying to make money selling useless BMS's that do more harm than good.
Isn't that right Morph?
AndyH said:Do you see the cells that sag the lowest in my chart? Those were the ones that have been below 1.4V before I installed cell-level LVC. You can also see that the cells come back to similar voltages once the load is removed. So no - I don't think that you'll get any useful information by measuring the static voltage after a short ride.
Ever see the car battery test units garages and some parts stores have? They diagnose a battery not by measuring the static voltge but by watching performance under a load...
Now that you've read these last two 'paragraphs' - please go back and look at the chart and see that the cells that sag the deepest do NOT have the lowest static voltage once the load is removed. Please take a minute or three and let that sink in. You cannot tell the condition of the cell by measuring the static voltage.
Andy
nomad85 said:I don't think the cycle analyst will do what you want morph. When I used mine to limit current, all it did was cut throttle when the current exceeded the set level, then turned the throttle back on when it was below, so it was like a stutter, and I stopped using it.
