Will
Crisis no.#1 is here. 3/31 7p western zone, me and my e-bike are outta across the country to AL/GA. It will be my sole transportation for 2 weeks. I noticed a loose wire in the battery box and an inspection showed the small charger wires had come off. I can't even do a decent solder, and am not about to put heat to a lith battery in an attempt to connect the charger wires (see photo). The charger wires should go in just below the black power wire and above the charger connector on the battery's edge (look at blurry picture closely
). Would it work to put an anderson connector onto the charger wires, then unplug the battery from the motor and use the larger power wires to connect to the charger? What I'm unsure about is, do those wires go thru the BSM system? Is it like charging a car battery with jumper cables?
