__Tango
1 W
Hi folks.
I'm trying to figure out how close the specified charge voltage needs to be compared to the pack voltage when using a BMS. Specifically the Fechter/Goodrum BMS.
Let me explain a little...
I'm building an e-motorcycle that i'm hoping to get 36 Thundersky LiFePO4 batteries into. If i can't fit all 36, i'm pretty sure i can get 32 or 30.
I've sized most of the system (controller, motor) so that it can handle the max amount of batteries, and i'm using a Fechter Goodrum BMS, so making that handle 30/32/36 batteries is easy enough.
The charger however, is where i'm confused. Can i just get a charger that does more than 133.2V (36 * 3.7V) and let the BMS take care of the rest? What if i use this same charge voltage (133.2V+) but on the 32 cell pack (118.4V at 32 * 3.7V), again using the Fechter/Goodrum BMS for 32 cells. Will that still work?
Does it matter if the charger is a CC/CV charger that cuts over from CC to CV at 80%?
Thanks for helping me clear up from this confusion...
...tango...
...tango...
