garolittle
Question for the experts … If a cylindrical lithium ion cell does not have any wrapping or the white plastic O-ring gasket that goes in it, could you put a paper O-ring gasket in it rewrap it and expect it to be just as safe as the original set up? A .25mm thick copper sheet will be spot welded to the cathode and anode side. Is there a risk of a "shoulder short" on the cathode side if there is a paper gasket instead of the original plastic gasket? Hope that makes sense. Thanks. :thumb:
