I have 3 12-volt batteries that I want to put into parallel for my 12-volt tools and then I want to put them into series for use in my 36-volt tools. While I could do this by unplugging the connectors and plugging them in by the right way, I was hoping for something a bit faster for the switch from parallel to series and vice versa, ideally through something like a switch. Does anyone have a switching diagram or instructions for such a switch if it's possible?
Right now, the only thing I can think of is creating two different circuit boards with the appropriate connections so that one is the "series board" and the other is the "parallel board", and then the batteries leads would plug into one board for 12Volt output and then plugged into the other board for 36 volt output (Or, some kind of equivalent wiring could be used instead of circuit boards). But, a switch would be whole lot faster and more convenient if possible. Thanks!
