RecklessMaker
10 µW
Parting out the old battery from my 2012 Ford Focus Electric.
Technical Details
Module Configurations: 4s5p (full), 2s5p (half)
Cells are marked LGX P1.
Nominal cell capacity: 14.9Ah/53.5Wh (calculations below)
Actual Capacity: ~10.8Ah/40.7Wh
Approximate Dimensions (Length × Width × Height): 280×65×190mm (half modules) 280×130×190mm (full modules)
Balance Connectors: Molex Micro-Fit (schematic below)
Price
4s5p modules (20 available):$160 $100 each
2s5p modules (3 available):$80 $50 each
Shipping: Pickup only
Flavor Text
Modules are in good shape and work perfectly. They still have lots of life left, they just can't be used in the car anymore due to a design flaw with the cooling system.
These are pickup only due to hazardous material shipping regulations. I also have all of the wiring, busbars, links, BMS modules, and cooling components available on request.
Paul
Technical Details
Nominal pack capacity (when new) was 23kWh. Given the pack configuration was 86s5p, nominal cell capacity (when new) is either (assuming a nominal cell voltage of 3.6V).
Price
Flavor Text
Originally there were heat exchanger plates between each cell. Ford connected these with slip-fit tube segments, but neglected to clamp the cell stacks. Since each cell stack contains hundreds of cells, each cell only has to expand a tiny amount (like what happens over time with normal use) to cause enough displacement to pull the coolant pipes apart. The "fix" is to remove the heat exchangers between each cell, but this makes the car almost undriveable in hot climates.
Paul
