dgk02
I took the new Ebike for its first trip today, and noticed that the PAS mode is significantly faster than full throttle. Since it's only a QT100 motor running at 36 volts, that isn't really very fast but it was unexpected. I'm guessing that PAS ignores the three wire "three speed" connector which comes from the throttle and connects to the controller. The controller documentation refers to it as the three speed connector but gives no information on what to do except that orange is fast, black (GND) is medium and green is slow. Since all are connected to the three wires from the throttle, I could use a suggestion as to how to connect it so that I get the fast mode. The colors do not actually match the colors in the documentation but it clearly is the proper connection.
There are two other connectors that are coming from the throttle that are not connected to the controller at the moment. One is probably the button, which I'll likely connect to the red (+) wire from the PAS sensor and hope that it works to disable PAS. The other unused connector must have something to do with the battery level lights, and that is handled by the Display unit so is not necessary on the throttle.
So far it's all working pretty well, and I've certainly learned a lot.
