Hi everyone, I'm new to the forums. Justin from Grin Technology suggested I join to obtain some information I'm looking to get for a build.
I want to wire two Lifepo4 48 Volt 20ah batteries together in series for about 100volts . Yes these are the Chinese ones that come already wrapped with a BMS. (Pic attached)
Justin from Grin said I would need to wire a pass diode to protect each BMS and I'm not sure how to do this. I looked already on the forums and there was some talk about pass diodes but I didn't see anything that made it too clear to me as to what size to use and how to wire them into the setup.
The BMS's are rated for maximum continuous discharge of 60A and a instantaneous maximum discharge current 120A. (I've attached a pic of my BMS, 16 series)
Could someone please dumb it down for me. I'm sorta learning as I go along. What kind of diode do I need? Is there a particular direction the diode needs to be used? Where in the setup do the diodes get placed?
A diagram would be fantastic if someone could post something for me showing where to wire them in.
Jason
Jason
