Perpetual motion "regenerative acceleration"
Paul_G
Syracuse NY
some far out thinking but it seems to work and he used a hub motor on a few.
http://evworld.com/article.cfm?storyid=1890
http://green.autoblog.com/2012/02/15/perpetual-motion-regenerative-acceleration-returns-as-regenx-i/#continued
from the second link:
"Heins claims that his system:
create a repelling magnetic field until the generator's rotor magnetic field is top dead center to the coil. At this time (TDC) the ReGenX generator coil produces a delayed repelling magnetic field which repels the rotor's magnetic field with additional force which is now already moving away from the coil. The result is a reversal of the electromotive force induced inside the ReGenX generator from a counter-electromotive force to complimentary-electromotive force."
We need LFP here, urgent !
Can't believe this crap made it all the way over here...
Perpetual motion is impossible and yes, you are inviting some people who understand electric motors like the back of their hand to jump on your case here :p
BTW i am "2 wheeled menace" on autoblog green.
Doesn't sound like he is claiming perpetual motion. Seems like all that is being said is, you can charge your batteries (via regen) when accelerating, not just decelerating.
So let me get this straight. He spins up the motor, creating a magnetic feild in the generator in the process (this takes energy), then he "reverses the polarity of the feild" and releases that energy back. That will either accelerate the system, or charge batteries.
Wow. Yawn.
could be it uses time crystals in the 4th dimension? :wink:
http://www.sciencenews.org/view/generic/id/338500/title/Crystals_may_be_possible_in_time_as_well_as_space
anything is possible just not figured out yet.
Transparent aluminum, laddie...thats the ticket!
Ask, and you shall receive... "Transparent Aluminum Now A Reality"
http://www.ubergizmo.com/2015/11/transparent-aluminum/
(actually a mineral, it’s magnesium aluminate)
Sanghera further describes the manufacturing process, so to speak, “You put the powder in [a hot press], you press it under vacuum, squash this powder together—and if you can do that right, then you can get rid of all the entrapped air, and all of a sudden it comes out of there clear-looking.” When the sheet is fresh off the press, it will be ground and polished before being refined further into other uses like bulletproof glass. Should the cost come down in due time, then consumer applications will also benefit, including smartphones and watches.
