Phase current setting Lyen 12 fet
Simple818
Glendale,Ca. USA
My setup: mxus 3t in 17" rim. 20s 16ah Lipo multistar. Lyen 12 fet.
I am having trouble with the batt to phase ratio. It seems I should be able to get a mich higher phase setting. I right now have it at 60/90. If I adjust the phase amp any higher my motor seems to Chug really bad at higher speeds. I also have a 3 speed switch set to 70/95/110%.
Shouldn't I be able to set the phase to like 150 and batt to 60 without issue. Is it because my traces are not modified. Nor are my phase cables going to the motor?
Any ideas?
