simplystupid
- Joined
- Jul 20, 2015
- Messages
- 14
Hi, memory loss is my excuse for having lost the answer Miles gave to this last year.
Using Bosch starter planetary ring of 47 teeth, carrier planets have 16 teeth.
I think Miles said 15 or 14 teeth on the sun.
Computer blew up with his answer saved on it.
The OD of the planets is 13.2mm.
OD = (N+2) x MOD
So MOD is 0.733333
Possibly MOD 0.75 with some adjustment having been made to the profiles actually being used?
Maximum space between tooth roots of two opposite planets is 11.2mm. Not enough room for 14 or 15 teeth?
Even if a carrier has unevenly spaced planets, they always seem to be opposed in pairs across the centre sun axis. Cutaway views of this starter show this arrangement.
Based on the OD space available, I originally made a brass 13 tooth sun, which didn't work. And was nigh on impossible to get off even with a blowtorch, after using threadlock.
It should really be hardened steel, aka silver steel, which is so difficult and tedious to broach that I wouldn't want to make another tooth count error.
Mark
OD = (N+2) x MOD
So MOD is 0.733333
Mark
