rocketman58
- Joined
- Aug 6, 2022
- Messages
- 77
When I grip my back wheel and move it from left to right while it is mounted in the frame there is some play in the hub. I checked to make sure everything is bolted on tight, and it is. I have yet to take it off the trike, but it seems like something is loose inside the hub motor. The motor runs just fine. I discovered this by accident while cleaning the trike. Would worn bearings cause this? The motor is less than two years old and has less than 800 miles on it.
