I have a new trike with no miles on it. Bought from a retailer in California and I live in Canada. Worked with retailer but they know less than I do. They replaced the trike once with one that acted the same. Left the trike with me due to exorbitant freight costs to return it and refunded my money. That was great but I have a brand-new trike sitting in my garage that is taking up space and wondered if anyone on this forum might have suggestions how to fix it.
Here's my problem: The PAS doesn't work at all. When you touch the throttle or the pedals in any PAS level, the trike takes off and will go to 32kms/hr on the speedometer, which is the cutout. The actual speed is about 15 to 20 Kms measured by my other trike. The only speed control is the throttle or the brake. The controller is a SCIWIL SW900. The motor is a 750W front wheel drive. The retailer provided me with all of the codes, and I have checked them and even played around with changing them. I removed the controller and checked all of the connections, and everything is tight, as are all the other connections. I don't think my problem is in the connections unless there is a bad wire or connection somewhere. The retailer thought it might be the motor and sent me a new front wheel. That wasn't the problem. I'm wondering if the builder in China got a bad batch of controllers. I'd appreciate any help I can get. Thanks.
