Ch00paKabrA
I have searched around on the board but since the search function is not the best, I have been unable to find a definitive answer to my question.
Here is my question:
Can I run my sensored hub motor with a sensorless controller?
Here is why I want to know:
My motor is a Bafang 36v 250w motor that I am currently running on 72v 250w. It is a slow (torque - 175 rpm) wind and on 36 volts, it will do just under 20 in 29er rim with a 2.35 tire. On 72 volts it will do almost 30 but it takes a while to get up there. I want to run it on either 500w or 750 but I believe it would be in my best interest to increasee the size of the phase wires before doing so. The problem is that there is not enough room to increase the phase wires unless I eliminate the hall wires.
Thank you in advance for your kind replies and I bow to your superior knowledge
'Cal
'Cal
