HI, just joined but have read alot, but could not find an answer to my problem. Problem is ,I attached my new ku65 controller to my self build ( unknown motor) 24volt system and it worked imediately, till I turned the throttle off. Since then only the 6 kpm button works. These are second hand parts except the controller. I tested the motor ( has only 3 phase wires ) by shorting out a pair of phase wires at a time and rotating the wheel backwards. Each time I am getting heavy restance. Also checked if there was any shorting to the hub itself( no short ). Have 5v by the throttle and the throttle shows varing voltage when turned. I have a version 7 PAS sensor and a version 5 PAS sensor (the other one I bought to see if the other one was not broken ). I just recharged my li-polymer battery and imediatly checked the voltage. It was 29.2, half hour later 29.2, 1 hour later 29.2, 2 hours later 29.2 . Got fustrated and and left it.Tried it a few times ( once a month ) . Still the same, only the 6kpm button works. Motor fine, battery is fine. 6 Months later I try it again and guess what, it works again, till I let the throttle go. Again fustration. Only the 6 kpm button works. Does any one have an idea what it could be?
Luckless
Luckless
