Hi, I bought a Q100C 36V350W rear driving hub with 328RPMs and a KU93 controller from BMS battery. In mode 1 I have no problems but when I switch to mode 2 or 3 the bike accelerates but sudddenly there comes a screaming sound from the motor and it stops. I have to reset the controll panel to make it work again. I also tried the thumb throttle only (no PAS) with the same result. It seems to me that high loads are the problem. I got an old KU65 from a friend and with this controller everything worked fine. So I ordered a KU65 and got a controller named KU63/65 cause the old one is no longer availibe. Here I have the same behavior as with the KU93. Does anyone have an idea what the problem could be? What would be the right controller for the motor?
