Boomerpilot
- Joined
- Sep 8, 2012
- Messages
- 13
Have a new 48V20Ah liFepo4 from Sun thing. Had one good 20 mile ride with everything normal. Next ride( after battery charged) made it about 5 miles when motor cut out. Seemed as if could reset battery( BMS?) by unplugging connection to controller from battery( battery would act strong but then cut out shortly again). Recharged overnite and had same experience again. Battery read 51 V when cutting out. Battery only reading 55V when fully charged. Got a new quality charger but seems to make no differance. I opened the battery so could see the BMS which has led lights. While recharging eventually saw lights gradually mostly illuminate and at one point measured 58 V from battery. However left on charger overnite and next day, no LEDs lit and battery back to 55 Volts.
Measured individual cells and mostly 3.47 V with two lowest at 3.35 V.
I am quite a newby, but based on what I have learned on this great forum I am thinking the BMS is bad. Some reason it is not allowing battery to fully charge? I also think it is cutting out battery prematurely when in use for some reason? But why with battery still showing 51 V?
Prior had a 36 V lead acid. When I reinstall this the bike performs as it used to, so don't think a controller/motor problem.
Bike is a conversion using a ebike kit controller (20amp) and 500W motor. Controller literature says ok for 48 V.
Any thoughts or help appreciated
