WUXI CMOTO INTERNATIONAL
New here
CMOTO
Hi everyone,
I'm posting from Wuxi, China. Our team (Cmotos) has been developing a new electric sportbike chassis, and I wanted to share the specs with the ES community to get some technical feedback before we finalize the production configuration.
We are trying to build a solid full-sized commuter that looks like a sportbike but offers practical range and decent speed for city riding.
The Project (Model: CMEM-SR55)Unlike many small-frame electric bikes, we are using a full-size 17-inch wheel platform with a trellis-style frame.
Here are the raw specs from our current prototype:
Attached are the photos of the bike and the spec sheet.
Hi everyone,
- Motor: 3000W Hub Motor (QS style). We chose a hub motor for efficiency and simplicity in this price bracket.
- Battery: Lithium 72V 120Ah.
- Note: We are aiming for maximum range here. I know 120Ah is massive for a 3kW bike, but we managed to fit it in the fairing.
- Controller: Configured for high phase current to help with acceleration off the line.
- Top Speed: Testing shows stable 80-100 km/h (GPS), which handles most urban highways.
- Wheels/Tires: Front 110/70-17, Rear 140/70-17.
- Brakes: Dual disc front, single disc rear.
- Dimensions: 1405mm Wheelbase, 180mm Ground Clearance.
- Battery Weight vs. Range: With the 72V 120Ah setup, the bike is heavier (approx 130kg+ gross weight). Do you think the trade-off for the massive range is worth it for a daily commuter? Or would you prefer a lighter 60Ah swappable setup?
- Hub Motor Heat: For those running 3kW hub motors at 100km/h for sustained periods, have you run into overheating issues? We are considering adding ferrofluid or hub sinks (cooling fins) as a factory option.
- Tire Choice: We are currently using standard street compounds. For a hub motor build, do you recommend going wider on the rear (e.g., 150) for looks, or sticking to 140 for efficiency?
