fellow
Clutch is repaired and reinforced (upgraded springs), it works well at 7A*75V=525W cont, 14A*75V=1050W peak. Default phase current less than 30A. I will probably use Redline DCTF (Dual Clutch Transmission Fluid) instead of the standard Biltema ATF (Automatic Transmission Fluid) I've used before. This is the absolute clutch power limit, as the Cwah said before. More than this is only possible by locking the clutch, ie using the brute and unelegant approach.
Cwah: No more wizardry please
. By the way, what is the nylon gears power limit?
Oh no, it is having babies!
The white frame to the left belongs to Mr. Wall Street, he was whining the whole sommer wanting one so I'm building it for him. It will probably became almost 1:1 copy of the Triebfluegel, as we ride together and he's sick of slowing me down
. The only difference is NCR18650GA cells instead of the PF ones (as those are discontinued). He is a very filthy old man not interested in airplanes and he will probably call it sexy lolita, gephard or something like that
. That project started today ordering bunch of parts.
The black frame to the right is a Heavy Transonic Bomber prototype. I will allow its mass to climb up to 30kg, giving some very interesting possibilities of the motor and the rim choices. Target power is about 3.3kW at 2 x 92V, target speed 60km/h. It is likely that it will have to wait for the next generation of the Panasonic 18650 cells before I start that project (GA cells are the "half-generation" as I see it).
