Hi All
I have used some time now searching the forum for answer, only to get more confused.
First of all.. I'm a grown child (44y) from Denmark, and I'm amazed to find so many fantastic people, with more or less crazy projects on this site :thumb:
My beginners project is really simple, or so i thought.
I have an old moped, most europeans know them well as the Puch Maxi, and I thought it would be brilliant to electrify my vintage moped.
From my reading i have found a ground idea of what I want, but need a little help on some specifics before placing the final order.
Im thinking :
Motor: 3KW QS hub motor V3, in a 17" rim. Its about 1.7m/rotation.
Battery: 72v 2100A 156Ah (build with 18650 li-ion, unless someone convince me otherwise)
Controller: Sabvoton Sine Wave Controller 150A (SVMC72150 if that's still good)
Speedometer: Cycle analyst V3
BMS: ?
My problem is that I simply can't figure out the perfect winding for the engine. I'm thinking the total weight with me on it will be 130-150Kg
I'm hoping for 80kpm topspeed on flat road, but thinking the "normal" cruise speed would be more like 40kpm.
The battery I will make from li-ion 18650, and I did some calculation on it but am not sure got it right.
Sony makes this US18650VTC5A 2600mAh 35A 3,6V.
60 of these batteries put together as 20 groupes of 3 would give me total 72V 2100A 156.000mAh, im thinking that would be ok for 150km at 40kph.
What about BMS.. what is my best choice here.
I surely am missing something else.. but let's make this a good start..
/Rasmus
Im thinking :
BMS: ?
/Rasmus
