PWD's Rocky Mountain Element - 2WD
pwd
Ontario, Canada
Thanks thundercamel. The pack is working out nicely and it seems that cell matching is definitely worth it (cells stay in excellent balance). If I was doing more pedal input at bicycle speeds I would have stuck with 14S too. I wanted a longer power band which is why I went up to 20S. My only complaint for this particular build is that the wheel base is very short. I may look into building a longer swing arm in the future.
From-A-To-B
Longmont, Colorado
I enjoyed reading through this thread, PWD— thanks for documenting and sharing the upgrade story of your bike! I hopped over here after reading through your Grom clone thread— another breeze of a read.
It sounds like you ride this bike all the time as a commuter. It’s fun to read threads from folks who are going the distance with their DIY builds. @mcintyretj was an early inspiration for me— it’s wild to see someone crank through thousands of miles on their commuter. At this point, do you have a sense of how many miles are on the frame?
FuzzyWuzzy
PWD, I just read through the whole thread. THANK YOU! You went many posts in so much detail.
Question for you: how did you wire your DC converter to the battery? The literature on this is surprisingly sparse
pwd
Ontario, Canada
Thanks for the comments! Unfortunately this bike doesn't get ridden much these days since I got my Grom clone up and running and my off-road build keeping me active all year. This build is mostly just an occasional ride now.
I'd estimate around 4000-5000 km or 2500 to 3125 miles on the frame.
The DC to DC is wired:
Battery + to VIN+ (red)
Battery - to VIN - (black)
VOUT is 12V+ output
Shared ground so just use battery negative for 12V-
I'm not using the 5V output at the moment
ZeroEm
San Antonio, TX
Thanks for the comments! Unfortunately this bike doesn't get ridden much these days since I got my Grom clone up and running and my off-road build keeping me active all year. This build mostly just an occasional ride now.
VOUT is 12V+ output
It was a good old bike. enjoyed keeping up as you went thru building it. Guess we all must move on at some point.
pwd
Ontario, Canada
I am having a slight issue with the motor temp gauge reading "sagging" or "dropping" when I really hammer the throttle. For example lets say I hit hit open throttle and am pulling peak current from my pack, the temp gauge will appear drop around 15%. When I let off the throttle, the temp reading jumps back up.
The temp guage is powered by a DC to DC board (pack voltage to 13.4 VDC) (positive and negative wire) and the 10K NTC thermister signal (one wire) is coming from the motor.
Any ideas? :?:
I believe I may have found a reason/remedy for this temp sensor issue. I just stumbled on this Tradeoffs for NTC Thermistors regarding 10K vs 100K vs 1Meg etc and didn't realize that a thermistor with a higher resistance is more "noise" resistant (but more prone to self heating). Perhaps if I was to do another temp meter setup; I'd try and go with one that uses 100k ohm instead of 10k ohm and the signal would be more stable.
