Carracing111
- Joined
- Jul 29, 2016
- Messages
- 12
Hello everyone !
This is my bike: https://endless-sphere.com/forums/viewtopic.php?t=84542
I need help, to configure the Adaptto Max-E controller !
Everything seems to be correct.
My battery is a 20S 12P LG HG2 with Adaptto BMS.
The throttle grip. Is a cheap, (the one that sells Qulbix ...) I think it is well connected.
The motor hall sensors, I think they are also well connected...
The Autodetect test is successful !
Everything seems to work fine, just the speed with the wheel in the air, is very low!
In the echo mode is about 40kmh.
In Normal mode it is 55kmh.
In Boost mode it is also 55kmh. The only difference with normal mode is that the acceleration is faster.
Seeing other configurations in the forum with the same controller-motor group I have come to see up to 170kmh with the wheel in the air!
I have two Adaptto Max-E controllers.
I have tried both, and I have the same result.
The controllers are new. This is normal ? What could it be ? Where do I start to look? I have not tried the bicycle on the street yet. I have to finish ordering all the wiring!
I can take photos if needed.
Thank you.
Thank you.
