Hey
I want to know what benefit I get from thicker phase wires vs original thin wire in performance measures. Also positive and negative battery wires are replaced. I know the resistance in the wire is less and the voltage drop is less because of that. What performance gain in power and effeciency do I get in the motor? (max power figures: 95 volt system, 350 phase amps, 150A max from battery side.)
Calculations beforehand did give an estimate of about 3v less voltage drop or( 1v instead of 4v which means resistance is 3 times less.) Does this simply mean that I have 150A x 3v = 450w extra power input "TO" the controller and even more "TO" the motor via the phase wires? (https://www.calculator.net/voltage-drop-calculator.html)
Before:
Battery positive and negative 1m each of 10AWG
Phase wires: possibly 1m 12-14AWG tinned copper
After:
All wires 4AWG oversized 25mm^2, almost 3AWG 1m each
Pics for fun and sharing
Before:
After:
