ebikeFan1234
I have a Stealth Bomber bike with QS273 motor, 4KW, 2.5T nominal and 8 KW peak. Detailed specs here.
This is paired with 72v 40 ah battery, Savoton 150A controller, 21" moto wheels
I am looking at upgrades for a very fast acceleration from standstill, esp 0-30 mph. And top speed with solid power delivery till 55 mph
For reference I have ridden a Talaria MX4 Sting R and it's startup torque is mind blowing. Its so high that one has to be careful with throttle otherwise it would wheelie. See detailed specs here. It indicates a max torque on the wheels at startup of 45 nm x 8.35 (gear ratio) = 375 nm
On the other hand, the QS273 4KW motor specs indicate a torque of 30-200 nm. The peak of 200 is still almost half of Talaria
Stepping upto QS273 8 KW motor has max torque of 266 nm.
I have few questions
How can I improve my current bike's acceleration and make it similar to Talaria?
Currently is bike is very anemic from 0-15 mph range. Then the power delivery is pretty solid until 50 mph or so. How can I improve 0-15 mph performance?
The QS Motors have different turns like 2.5T, 3.5T, 4T, 5T etc. How do the turns affect the torque, is there a graph that someone can share?
When is the max torque produced?
I assume its when the current is max. My current controller can feed 150 A. Can I tweak the controller to feed that much amps at startup?
If I go to a smaller wheel like 19" from the current 21", will it increase torque by 21/19 = 10% approx?
