Question about running two Calibike batteries in parallel
hackerboysf
I have two 48V, 10AH Calibike batteries with BMS built into them. Each battery has a built-in plug for its own charger. I am putting the batteries onto an electric gokart I'm making with my kids, which is run by a Lyen brushed motor controller.
I would like to wire the batteries up in parallel so that the gokart has essentially 48V and 20AH capacity. My question is this:
If I have the batteries wired in parallel, can I plug both batteries in to their respective chargers, or will I risk blowing up one or both batteries? If I cannot do this with the batteries as they came "out of the box", could I put a big diode onto the "+" leads from the batteries to prevent current going from one battery into the other?
What I'm aiming for is a safe, simple and fast way to charge the batteries. I figured it would be faster to plug both battery packs in to their chargers, but they weren't cheap and I'd hate to destroy them by doing something dumb. I could put some switches in place to isolate the batteries during charging, but kids (of all ages) tend to forget stuff like that. Since both batteries have a BMS and a charger, I thought it was logical that this issue might have been anticipated and protection built into the BMS.
Any input is much appreciated.
You've got it right about the diode. That will keep one pack from charging the other and possibly damaging it. Here's a screenshot from Ping's user guide about running two batteries in parallel. His whole user guide, which can be helpful for general battery wiring, can be found here: http://www.pingbattery.com/usrguide/Wiring%20Guide%20V2.5.pdf
