The Toecutter
- Joined
- Feb 8, 2015
- Messages
- 1,466
My Cycle Analyst V3.1 arrived. I read the user manual and on Page 34 it mentioned the following:
"4. Using a torque sensor on a high voltage system: Even though the CA on its own can handle up to 150V, this voltage needs to be derated when accessories are plugged in which draw significant current. Most torque sensors consume at least 20mA from the CA's 10V power bus, and that usually correlates to no more than 52V nominal battery packs. A torque sensor can be used with a high voltage ebike system if the power for the torque sensor is supplied externally and not through the 10V on the PAS plug."
This caught my attention because I am intent on using a 20S pack of LiIon batteries, which is 74V nominal. I don't want to destroy my Cycle Analyst computer or fry my Sempu torque sensing bottom bracket.
The Sempu's specs state it has a supply voltage of 10-60V DC. The working current is listed as less than or equal to 35 mA (at 12V).
I tried to do some searches on this site for what people have used for external power supplies for high voltage torque-sensing PAS setups and have not been successful finding info. I haven't been able to locate the necessary parameters for the Cycle analyst to do my own calculations regarding whether I could just use a 74V pack with this bottom bracket without exceeding the CA's current specs for the power bus, nor do I know if the supply voltage for the torque sensor is going to be a close match for the battery pack voltage.
I'd rather not have to go to a lower voltage pack, and I'd rather not destroy my components. Do any experienced builders have any solutions to offer?
