Ok So I think with lam stacks in a inner runner and outer runner motor we should be able to have a rule of thumb for torque vs the side of the stator.
IE with good cooling 1ft/lb per sq inch.
So Lets use colossus for instance its a 2.5" long x 4" dia stator. So we could say that with 1ft?lb per sq" that would be 4*3.14*2.5= 31.4 ft/lbs avalible for continuous duty with good cooling.
Now If I use the same numbers for a couple induction motor stators I have 6" long* 5" dia *3.14 = 94 sq inches which could meen 94 ft/lbs.
I have a 256t frame induction motor and it could be 7 long * 6 dia * 3.14 =131 sq inches so 131ft lbs.
I use 31 ft lbs for colossus because I think I can make it run continuous at that level. Might be hi but its maybe safe to say a well designed motor would be >1ft/lb per sq inch. What do you guys think.
IM not talking about weight. I have 4 induction motors I thing the stators will be a good score for big power induction motors.
