Hello,
Is there any harm done by charging your batteries using cheap chinese chargers for a quick charge? I currently use 36V (10S4P) packs, which does not have any built-in BMS (pack is home made). I normally charge these packs with iCharger 1010 to balance charge, but it takes much longer to charge than the bulk 4A/36volt li-ion charger, which I bought from Luna Cycles.
With the Bulk charger, I notice the packs are not charged evenly, and often the ( new Samsung 25R) cells can be off by 0.05 Volts. While this is not really an issue, but am I damaging the cells in the long run?
I also notice many users here use Power Supply to bulk charge, which obviously does not have the CC/CV charge algorithms. So what is the difference between using a cheap bulk charger/power supply vs using a decent charger like iCharger or a top of the line charger like Grin Satiator?
Has anyone here have experience using both methods of charging? Would it be worth investing in a high end charger like the Satiator? Or I should be ok with using cheap chinese chargers to bulk charge?
Any feedback would be greatly appreciated.
Thank you
Thank you
