QULBIX DIY Frame Q140MD
I bet that will make a huge difference. Tighten up that old machine a bit!
Indeed. Its working much better now.
Got the new controller in today and i wasnt aware how much smaller it is. 200 peak 100 continuous vs 300 peak 150 continuous.
The smaller it gets the better clearance i have for the front wheel when the shock compresses. This is an interesting development. My BMS only does 200 anyway, so maybe ill aim to.use the smaller controller. Saves weight too.
I could always set it up so that the big one can be attached if i wanted to do a straight line speed run, but i also want to get some output numbers from the bms before i assume theres anything more for it to give. Much more likely i get less then 200 out of it, but we shall see.
The copper bus bar is supposed to be in today or tmrw at the metal shop, then i can make some battery progress.
Had a go at one of the axles today. Lathe worked well, needed to do very shallow cuts on this 303 stainless, but we got there in the end.
Basic dimensions and bearing races and knurling is done. I need to flatten the end to fit the dropout style brackets and add the channel for the wiring. Thay will also be done on the lathe using the milling attachment to hold the work and an endmil in a collet in the lathe. Im not sure yet how to center the flats on the axle, ill have to research that part.
Ok, after some thought, the plan is to take down both ends to the just under 16mm mm they need to be for the rear swingarm bearings, then use a er-32 collet and collet block to mount the axle directly in the milling attachment. That way I can ensure that the flats are parallel and centered by simply flipping the block.
Got a lot done over the last couple weeks. The bushings foe the rear wheel are made and installed, the read brake bracket is modified and mostly complete. Here is the bike in almost pedalable form.
You are getting close. What are your plans for the battery?
I just discovered that the new stealth bomber is now pushing $9k USD 😵‍💫 Though they are a really good bike
Sometimes DIY can pay off bigtime. :mrgreen:
I have a good battery spot welder, and .2mm nickel strip, and then I also have a bunch of 3.5 inch long 1/8 of an inch copper bar that I will solder to the nickel strip first, then spot weld the nickel to the cells.
I ordered some copper/nickel solder paste, and I'm hoping to clean the strips well then place small balls of the solder on the nickel strip then weigh down that on a silicon mat and oven heat the whole thing to the flash temp of the solder.
The cells are;
Molicel P45B 21700 4500mAh 45A Battery​
40s5p... 168 volt 22.5ah.
Ive got the cell holders, fish paper, and heatshrink. I'll be splitting the battery int he center to load it into the bike, then hard attaching it with either a welder quick disconnect or more copper strip bent and bolted to some sort of busbar attachment.
BMS is a DALY 200 amp 40s, so it will be protected and balanced and also monitorable via bluetooth.
One thing i need to finalise is the way it will anchor in the bike. Maybe straps, maybe solid mounting point in the fiberglass isolator board, maybe wedged with solidcore foam?
I want to be able to jump/lay down this thing so it cant be loose in there. Most companies would latch a hardcase somehow.
Depends on what you mean by depend. I mostly want it so that I can verify the cell voltage via bluetooth. I will trust it if it proves trustable. I'm not using it on lipo bricks.
Hey, what kind of bearings did you use for the swing arm pivot? i did not get any with the frame (did you?)
Also i'm struggling to find mounting hardware for the rear shock, any tips?
The outer diameter of the swingarm bearings is 1 3/8". The inner diameter varies depending on your motor axle width. I did get some with my frame, but I ended up ordering the ones below because I custom made my motor axle.
Rear shock always requires spacers to center them properly. You could use something as low tech as washers. In my case I will be making spacers on my lathe. Or you could use something like this;
Ah ok, I contacted qulbix about the missing bearings but they are on vacation :( I also had some other things missing from my order so I'll guess I have to wait a couple of weeks until I can finish my build.. so close though.
I could not find any premade shock hardware that suited the dimension of the qulbix frame, so I think I'll make my own aswell, or see if qulbix can supply them.
How did this go? curious about this build!
Been riding mine since last summer!
Not done but rides fine!
You have beaten me to the punch. I got to the point of rolling chassis last year, and then summer got here and the family took priority.
But I'm making progress now! I've been working for the last couple weeks.
All the controls are mounted, I now have a J1772 port for charging, the battery is half assembled and I'm waiting on more nickel strip on monday to finalize that. Once the battery is finalized i can finish the control wiring once I know where the connector block will fit.
Let's just say that the number of cells im trying to fit makes everything... tight...
Coming Soon....
Well it took a few more years then I originally planned. Had a kid in the middle of it who is now most of the way to 2 years old... But its almost done. I rode it a bunch today and it's just ridiculous.
The DALY BMS is working just fine from a power delivery point of view, even if the software is a little annoying.
The Kelly is doing the variable regen I want using a throttle on each side, one for power one for regen. The brake switches cut the throttle but don't trigger regen.
40s5p charging just fine, the very last thing I need to do is pin out all the wires for the 40s connector that goes to the external balancing solution, the Pentagon of Power. This is 5 8s QNBBM balancers daisy chained together for 40s cell level balancing when charging.
Welp... I bought a full set of lightweight but properly rated motorcycle gear cause I like my skin.
Put mirrors on there too.
Then today I did my first test speed run in full gear. 118km/h and there was more in there for sure, but to be honest I got slightly scared.
I AM OOOOOOLD. Where is that care free "never gonna die" attitude, old man??
I swapped the rear sprocket from 49 to 64 tooth and it made an enormous difference to how smooth and responsive both the throttle and the regen are. Everything that was jerky and difficult to modulate is now pretty much perfect.
Bike became pedalable too without the motor, and easier to push arround.
I suspect I'm top speed wattage limited rather then rpm limited, so It's possible this doesn't change the top speed at all. It definitely still does 100 km/h with more left over.
