tikivic
1 W
Actually it was easier than I thought. I thought I would either have to machine it or use a press (swingarm is steel - not aluminum). But in the end I used a 10mm threaded rod, 2 nuts, washers and thrust bearings and just kept expanding it equally on both sides till I ended up about 9mm wider. I did have to spread it quite a bit wider though because it does spring back somewhat. Not elegant, but it worked. See pics:
BTW...lacing a Rohloff into a 19" moto wheel was interesting. In the end I cut my own custom length spokes and threaded them with a Hozan C-700 spoke threading machine (3 times till I got the length exactly right!). I used the custom nipples from Holmes Hobby in the rim (along with washers).
http://holmeshobbies.com/bike-and-moped/spokes/14g-moped-nipple-black.html
