Chalo
100 TW
Cees said:@ Chalo. At steady full speed the power is about 350 W during acceleration the power is at 960 W.
350W of electrical power will be something less than 300W of power at the shaft, after efficiency losses. Run the speed calculator again with say 260W of power input. That's what you can expect.
The good news is that your bike is running in a highly efficient speed range (for the motor). The bad news is that you'll have to increase either your battery voltage or your wheel diameter to increase your bike's speed. Or you can switch to a motor that runs at higher RPM.
