I've had a knocking/rattling noise from my BBS02B for a while and have talked to the reseller who has been less than helpful unfortunately. I've disassembled the motor and thr bottom rotor bearing seems fine and came off still attached to the rotor. The top shaft that connects to the nylon gears is loose however. I first thought the o-ring was missing and needed to be replaced, but reading through the forum I saw that the shaft diameter should be exactly 8.0mm. Mine is 7.7mm..
Would a new rotor solve this issue, or is the bearing most likely toast as well?
