Peter Sternersson
Just came back after an aweful ride on my newly built greyborg frame.
I bought a new spring for my Fox shock, took the stiffest I could find at 550lbs/inch.
But it bottoms out like crazy, ruined my rear light cause the tire got so far up.
I made a extension on the upper mount to make the spring act stiffer, moved the hole about 70mm back I think.
Also, I have cut the swing 25mm shorter, and tre frame 50mm shorter in front.
Soo, what spring rates do you folks out there run on a greyborg frame with the latest swing arm? (or bikes with similar geometry)
It feels like a 1000lbs-1200lbs spring mounted at the correct upper hole would not be to exaggerate. But then you have to go look at dirt bike shocks I guess?
