Compoundbike
I purchased an older specialized turbo (2013) with a hub motor.
The battery didn`t work, so I opened the battery for replacing the cells but I figured out the problem is more than the Cell output voltage (because the cells had enough Voltage).
First of all, there is a button battery around the BMS. Also, there are some cables that are being connected to the output of the battery.
I saw a German guy on another forum bypassing the Battery with Goswissdrive Display and it seems to work if you don`t want to use an original Battery with the "specialized" internals...
Did anyone else try to bypass the original Specialized Battery ?
