www.recumbents.com
I was thinking about a different type of electric motor last night while staring at the ceiling in the middle of the night.
This motor would use large solenoids to drive pushrods which drive a driveshaft. It would basically be the electric analog of a reciprocating combustion engine. I'm sure it would be less efficient than a normal rotating electric motor, because it would require lots of bearings. Also that conservation of momentum thing would go right out the window with the solenoids going up and down. It would be a cool project though, and it would look and probably sound very cool on an ebike. You could almost use the block from a 4 cylinder motorcycle engine and just replace the pistons with big solenoids.
I'm not looking to build this, I just thought it was interesting and wondered if it had been done before.
-Warren.
-Warren.
