lynchy said:
I'm going to have a go at cutting some spokes to length and threading them. Just need to buy the right size dye (is that the right spelling? :? ) So tired of going to every bike shop around trying to find the right spokes.
Don't. And I speak from experiance. Cut threads on spokes are near useless.
The won't grip the nipple right and are almost 4 times weaker than rolled threads.
Cut threads remove material from the shaft, making the shaft thinner at the point of the thread. rolled threads compress steel into the shaft, making the steel stronger, and also push the steel up into ridges of the threads, making the thread's wider than the shaft, so they seat and grip into the nipples better.
Whats needed is a thread roller like a Phil Wood. Unfortunatly, they run $3000 used, But most reputable bikeshops will have one.
I know around Dallas the cost of 40 raw spokes, or 40 spokes cut to leingth and threaded propperly is the same. about $40.
If you are looking on line, Justin or Zev from Ebikes.ca can cut spokes, and they roll the threads. IRRC, it was $40 for the 40 spokes I had made up in black.
