Based on your results ... I would consider using the best 105 only and charge to only 4.05V.
Balance charging often!
But!
I would recommend equalizing all cells to exact same voltage before testing for self discharge.
I used to solder all cells together ... but now I combine using small neodymium magnet discs and thin steel wire.
Take lowest cells (within .10V) and link together,
begin charging and when charged voltage approaches remaining cells add them, Allow to charge till charged to ~4.20V.
Remove from charger. ...
Important - Cells will not be of equal voltage yet!
Leave cells attached in parallel for a few hours.
Separate and confirm all cells of precisely equal voltage, might be ~4.15V.
Let set several days before rating self-discharge
.001V capability is desirable but not "necessary".
Panasonic NCR18650A specs -
Most notable might be the capacity deterioration from their test cycles.
Graph shows 80% rated capacity after 500 cycles.
Charging to only 4.05V and not discharging below 3.20-3.30V (during .5C discharge) should possibly triple usable life.
Should have same capacity after 250 cycles, better capacity at 500 cycles and much much better capacity past 1000 cycles!
Even at the lower charged voltage, might have better usable capacity after 1000 cycles than the 4.20V charged cells have after 500 cycles! ... ?
