Doctorbass
I had an ides few month ago about the way to solve the probelm with regen difficulty at low speed or when using high voltage battery.
The main problem is that to regen and brake, the voltage that the motor produce MUST be higher than the battery voltage.. or in other words, would only work if the speed you have is higher than the max speed you can reach with throttle wide open..
Let say you run max at 55kph. that mean that to regen, the speed you will need must be 56+kph.
The reason is that if the voltage you have to run 55kph is 48V, so when you go downhill and reach 54kph, you will still have no regen.. but when tou will reach higher than 55kpg, the voltage produced by your motor will be higher so the current will flow to regen.
To regen, you must have reverse current between your battery and motor. to have current, you need a positive delta V from the motor to the battery.
The only way to regen or be able to brake using this method is to boost the voltage of your motor in regen mode.
DCDc have input-output isolated so you can add the output vltage of those to their input in serie to boost the voltage and then get current to regen.
This exemple show this booster idea i had:
Doc
Doc
