Hi, the charger for my ebike has died after 5 years of use, and I'm looking for a replacement. Biggest priorities are reliability, getting something that won't start a fire or damage the battery if I forget to unplug it once the battery is fully charged, and is under $200. Fan or fanless is fine, don't care about charging the battery super fast, but having options to trickle charge or charge at a normal rate would be nice.
Battery is a Jumbo Shark 48V 17.5Ah, Samsung 35E cells, uses a 5.5mm barrel connector. Old charger was a UY180 rated at 3A.
Options I am currently aware of:
A local shop has a FTH power charger for $60. Sounds like a basic 3A charger with a plastic case that may or may not have a fan.
MeanWell power supply looks like a solid option, but there are so many different options available, and it sounds like an extra device might need to be paired with it when using it as a charger. Any advice on picking out which power supply to get and what to pair it with?
Luna Advanced charger looks like it would do exactly what I want, but might not be any more reliable than some other cheap charger. Any opinions?
Are there any other options worth considering?
