Removing speed limit from my e-bike
ron9630
I have this controller on my e-bike http://i.imgur.com/BIs3tUt.jpg http://i.imgur.com/7Ik6vqP.png (its a chinese one) and I would like to know which cable I should disconnect to remove the speed limit.
Tell me if you need any more details
I would cut one by one, utill the limit will disappear.. :eek:
I don't think it works like dismantling a bomb.. or maybe yes :D . Are you sure your ebike has a limited controller? Maybe if you could spot some controller specifications or if you share a link of the ebike model we could research about that controller :roll:
Hard to tell with them packed in still...but usually the speed limiter is a single wire, plugged back into a single wire of the same color. Usually white or gray. And "Speed" jokes aside, it should have a connector...don't go cutting anything.
You haven't given enough informaion. What bike is it? Does it have a LCD on the bars?
The parts are from Dapu Japan (there isnt any bike model you would know) and the speed limit is at 25 km/h
Tell me every color combination of every two wire connector on the controller.
All plugs on the controller will have two pins, or three, or six etc.
Please show all the colours for the ones with two pins on each plug.
I have managed to remove the speed limit, looks like it was just a white cable, thanks for the guy that suggested it here :)
Sorry to jump in on convo but i have unclipped the white wire and still stops pulling at 25kmh. ( nike is dyson hardtail evo 2015
I'm desperately trying to figure out how to eliminate the speed limit on the k800 I just bought, there's obviously one there because you're going along especially under downhill slope you can feel it stopping starting stopping starting like a governor I just want to eliminate it if I knew what wire was I'd cut it but I don't any suggestions anybody I've already been in the display and everything
I could still return it but would rather not overall happy with the bike except not able to get the speed that I know is there I know there's a limiter I've worked on this type of thing my whole life I just don't know exactly what's what don't want to go cutting wires there's probably a way of programming in the display or something I've already been to the settings but I mean outside of that appreciate the response
