Hi,
I bought a broken second hand EBike (Wayscral Easyway E1, or a very similar (if not the same) is a Wayscral Basy 315), which I am in the process of repairing. I suspect the problem with the bike is a faulty display/control, as when I opened it up, there was quite a bit of corrosion. After some cleaning with IPA, the control panel lights up, however the bike still does not function.
I suspect its likely impossible to find an identical replacement for the controls, so I think the best approach would be to replace the controller and add a matching display/controls.
The rear hub motor is a 26in, 250W 24V sensorless motor. There is no hand throttle, only PAS. I wouldn't be looking for anything fancy, just to get the bike going again and pass on to someone to use.
The current controller has the following inputs/outputs:
Any thoughts or recommendations?
- Battery input
- Output to motor (3 wires)
- Display control input (4 wires, VCC, GND, and 2 others)
- PAS input (VCC, GND & white)
- Brake lever input (only 1 input, but the two brake levers are connected to each other, VCC, GND & green)
